textboxtool
Gehe zu Seite Zurück  1, 2, 3, 4  Weiter
Neues Thema eröffnen   Neue Antwort erstellen Die Siedler von Catan Community Foren-Übersicht » Die inoffiziellen Themensets zum Kartenspiel
REIsound
Anmeldedatum: 23.10.2001
BeitragVerfasst am: Sa 02 Apr, 2005    Titel:
Hi AxeCrazy,
I would like to know, if the naming of the menues is placed in independant files. That would make it easier to translate the tool to several languages, i.e. Englisch or German (which I prefer ;-)).
Spielt alles und jeden *g*
DAS Spiel für die ital. Momente im Leben: Mamma Mia!
AxeCrazy
Anmeldedatum: 20.12.2001
Hi Axe,
a variabel place for the magic power would be the best to combine it with strength or tournament points. The size should be the same as in the normal magic cards.
When i use negativ values for strength points only a part of the numeral can be seen. With tournament points it is ok.
The whole idea of this thingy was that when peple ake new sets the 'look -a-like" That is why each symbol has a fixed place, so the symbol always has the same place over the sets. So a Variabel place for the magic sign would be not a good idea then i guess. Also positioning a variabel object may become a lot of work. It is not an image editor and was never intended to be. Of course everthing is possible, but it would be harder to make and harder to manage. I will add a default place for, see if it fits your needs.
Indeed the minus sign seems to give some problems, i will adapt it.
do you have the 'prefered font' for these letters installed? it looks somewhat different?
FONT
AxeCrazy
BeitragVerfasst am: So 03 Apr, 2005    Titel:
SebOeh hat Folgendes geschrieben:
High Axe,
I have just tested the tool and I have some questions and suggestions for improvement. First of all, I find it very helpful and I aknowledge you for doing it.
[*] My set is just in the project phase, so I am sure of changing some texts later. A saving button would avoid writing the whole text for each card again.
This is for now not an option, i always start creating my card after i am sure what the text will be. i will loook how much work it will be to make
[*]The textbox is exported as an image. Ist it possible to enhance the image porperties? For example to double the Pixelsize and get a better resolution
For now this is also not an option. The images i use have the resolution i use them with. ofcourse you can make them bigger if you what but the quality will not get any better from that.
[*]It isn't a big step to include an image above the textbox and to get a tool for constructing a whole card, is it?
It could be done, but that would mean the pc which runs the program needs a resolution of 1280x1024 at least, since i create the image by means of the screenshot functionallity. And since i do not have that kind of resolution :
i just use this tool to quicky and in a fixed way and text to a card, and the rest of the image proccessing i do with my photoshop version.
But offcourse adding the complete card can be done. I will look at it.
[*]On klicking on "Voorwarde" one gets the possibility of writing a new line, but the 4th line is overwritten. What is the purpose of it?
i always use the last line (4) for the condition of the card(which cards are required to play this card) The 'voorwaarde'(condition) line can be used in combination with line 4 to squize in some extra words. Just Left align line 4 (add spacces at the end) And Right align the voorwaarde regel
(add spaces in for of the text (See example)
[*] On the original cards the top of the textbox is saying, which kind of card it is, e.g. "Ereignis". There isn't this possible with the tool. Anyway, this has no significance, since anyone recognize the type of the card by the color of it.
This option is not available since we do not have these text on our cards in the netherlands.
Could be added.
[*]Finally, I don't know many other sets and would like to know, what the symbols on the right side mean. It would be nice to be able to also use other symbols instead.
All these symbols are used in various sets as they are available on das-leinhaus.
it best a german college gives the right names for them.
fist-head-extra handcard-searching piles-ship-culturepoint-shield
greetz
AxeCrazy
REIsound hat Folgendes geschrieben:
Hi AxeCrazy,
I will try to add the all and make the language selectable, since only 6 words are used now.
Could someone write down the righ german words please ;)
@SebOeh: Die Symbole stehen für folgendes:
Eisenfaust - Stärkepunkte
Ritterkopf - Turnierpunkte
Karten - Handkarten (s. Bibliothek)
Stapel - Verbilligung beim Kartenaussuchen (s. HdV)
Mühle (Orange) - Handelspukte
Mühle (grau) - neg. Handelspunkte
Schiff - Verbilligung beim Flottenbau (s. Werft)
Säule - Kulturpunkte (s. inoff. Set Kunst&Musik)
Schild - Gebäude mit Schutzfunktion (s. Feuerwache)
Fahne (rot auf blau) - Siegpunkt
Fahne (rot auf Gelb) - Siegpunkt eines Weltwunders ( s. inoff. Set Meere&Wunder)
Die Erklärungen waren von mir, da war ich mal ausnahmsweise nicht eingeloggt.
niceday
Anmeldedatum: 05.03.2005
BeitragVerfasst am: Mi 06 Apr, 2005    Titel:
Hey Axe. I just discovered this tool. Very useful. Thx.
But there isn't a Ertragreiches Jahr (Goede Jaar) symbol neither one for "you get gold"...
Could you add these too, please ?
Greetz
niceday
Mitglied der Feuerteufel
SebOeh
Anmeldedatum: 26.08.2003
niceday hat Folgendes geschrieben:
There isn't such a symbol on the real official cards neither. Why to create a symbol for this? You cannot invent a new symbol for any card or game action. That's how I see it.
@SebOeh: Of course there is a symbol for this, look at "Kaperflotte", "Schatzflotte" and "Zollstation"
Seite 2 von 4
